I had some help last fall removing heads off my 69 Polara 318. It was running very rough and had lots of loss of power. Anyways, #1 cylinder was very low on compression. Upon removal of pass. side head, one of #1 valves was visibly burnt. Sent both heads out to local machine shop and had them reworked. The guy that helped me diagnose (he did leak down test) and remove heads is no longer available to help me install them. Machine shop provided to me new head gaskets. Is it a big deal to install heads? I’ve removed and replaced an intake by myself before on a 70 Fury 318 (the crossover was plugged up with carbon/choke wouldn’t work) but I’ve never gotten any deeper into an engine. While I’d feel better with someone that’s experienced by my side, I’m considering doing it myself now. Is there certain things I should know before doing this on my own? I have cleaned the carbon off the top of all 8 pistons and the top of block up surrounding pistons (mating surfaces) with a wire wheel. Sprayed light oil over everything for over the winter. A friend said tighten center bolts first, other than that, I know nothing about it. I’ve fixed a lot of easy and tough problems over the years, installed lots of new parts on many of my old cars, done a lot of troubleshooting etc. I’m very handy that way but am not confident on this one. I wish I would have marked which side the heads came off. Basic knowledge to anyone that’s worked on engines before I’m sure…Are the heads marked anywhere (R-pass. and L-driver)? Thanks in advance…any tips would be much appreciated. Bob
