How do you install a water temp gauge when you don't have temp gauge in your factory cluster?
You'll have a sending unit of sorts in your water pump housing either way (idiot light or gauge) You'll have to replace the sending unit to an incremental unit if you want to convert to a gauge. ... most gauges come with their own sending unit from my experience.
I installed the sensor for the gauge in front of the waterpump housing. It's located just below the outlets for the heatercore. In my 383 there was a little plug witch you can remove and screw the sensor in. But be carefull: as soon you have a tempgauge installed, you probably will get worried about the temp
(see my other thread...)
Your welcome...I use gauges from Speedhut. Please look at my other thread to see pictures..Thank you! What brand gauge did you use?
