Lordofthepings777
so I’m working on a 400 engine out of my car, and I’m doing a full rebuild. Taking apart the engine wasn’t bad, but I struggled to get the old camshaft out a bit. I actually had to slightly beat it out of the motor with a dead blow hammer.
Anyways, about a month or a month and half ago I took out my old cam bearings in plans to replace them. The old ones look rough, so I opted for new ones installed myself for the first time. Made sure oiling holes lined up and everything. Then- I go to put my new cam in recently and it doesn’t want to go all the way in. I end up buggering these new ones up (clevite brand) because the cam just won’t go in. I figure “it’s my first time maybe I didn’t do it right”. Last time I borrowed by buddies tool, so I bought a used lisle tool of higher quality, and began to take out my newly installed ones one by one to see if I could get it to go in. I removed the cam bearings one by one to see if the reminder would fit with the camshaft in the block, but none would fit.
Lastly, I decided I’d try and install one bearing in the rear of the engine making sure I take proper precautions, and it STILL would not fit after lining up the oiling hole and making sure it was all the way back on the tool so it seats flat in the block.
Now I’m just confused. Has anybody EVER had any cam bearing issues like this before where the new AND old crank will not fit in the block even after changing the bearings? I wish I had checked if it would fit back in before I removed the original ones, but I didn’t.
Keep in mind this motor locked up, and it struggled to turn when it would turn over. Could there be something that dramatically wrong? What should I do?
