Metalmarty
Hi All,
I've created a new thread since I've bought a new carb, which is working a lot better already.
Previous thread can be found over here : Holley 750dp lean secondary tip in
I've replaced my carb with a Brawler 670 vacuum secondary BR67256 and I'm currently trying to jet the Brawler for optimal performance.
With some small changes it's already working a lot better than the 750DP I had.
Driving on low load is going perfectly well, nice AFRs. Good throttle response.
However, it's going very lean when giving it more than half throttle, and it stays lean for multiple seconds before getting back to normal AFR readings.
The brawler 670CFM vacuum is new, out of the box.
Floats are set on the car, halfway sight glasses.
Idle screw are only a half (0.5) turn opened up, more is way too rich
Primaries are set to show just a little bit of the transfer slot (square) and secondary opening has factory setting.
Vacuum pot screw it set to one full turn (1.0). (was 1.5 from factory)
Idles at 900rpm.
Primaries:
- IFR 32
- LSAB 70
- HSAB 28
- Main jet 72
- PV 8.5"
- PVCR 43
- Squirter .35
- White cam
Secondaries:
- IFR 32
- LSAB 70
- HSAB 28
- Main jet 77
- PV plugged
Some background information.
I've got a wideband AFR gauge, vacuum gauge and rpm gauge installed.
- Idle vacuum is around 18inhg
- Steady state cruise vacuum is around 21 inhg (steady state 30mph and steady state 50mph)
Idle AFR is around 14.
Steady state cruise AFR is around 14 at 30mph and 50mph.
If cruising at 30 or 50mph and giving it more than half (or WOT) throttle it goes very lean (16-18AFR) for multiple seconds (with noticeable hesitation).
After a couple of seconds it seems to catch up, starts to pull hard and goes down to 12.5-13.0 AFR, which is perfect.
Car information.
It's a 1968 Chrysler Newport 4dr HT, weighs 4600 LBS.
- mopar BB 400 ('77 smog era, around 7.5:1 real compression)
- Stock 452 heads
- Edelbrock dp4b intake (aluminium dual plane)
- Brawler BR67256
- Mopar performance style electronic ignition, 16 initial, 38 all in
- Stock .430/.434 cam
- hedman 78070 headers with 2x 2.5" full dual exhaust with magnaflow mufflers and AP resonators
- 2300 stall converter
- 3.23 gears
Does anyone have any tips for me what I can do to get rid of the lean spot?
I've got a box of main jets (64 upto 99)
If got a box of air bleeds on the way (.065 - .075)
I've got multiple power valves (5.5, 6.5, 8.5, 10.5) (I've tried 10.5" since I'm getting 21" at 30/50mph steady state), but that opens too early, making the lean spot at high load way worse)
I'm planning to up the LSAB from 70 to 73 to get a better response out of the idle mixture screws.
They are really touchy and opening them more than half a turn makes it pig rich.
Adjustable vacuum pot screw is screwed out 1 full turn (was 1.5 turn from factory). Should that be turned in even more?
What more should I do?
Idles at 900rpm.
Primaries:
- IFR 32
- LSAB 70
- HSAB 28
- Main jet 72
- PV 8.5"
- PVCR 43
- Squirter .35
- White cam
Secondaries:
- IFR 32
- LSAB 70
- HSAB 28
- Main jet 77
- PV plugged
Car information.
- Stock 452 heads
- Brawler BR67256
- 3.23 gears
