66SportFury
Hey guys, I've done this before, but want to hear from you guys were you lift a big block to get the motor mounts out.
I've done it a bunch of ways but usually do the old 2x6 under the oil pan with a jack if I don't have an engine hoist which I do now. Make sure the board is wider than the base of the pan or it will cave it in a bit. If I have a hoist I use it to lift the front of the engine. Swing by the house and we can knock it out and have a beer! LMAO. One of these days I'm going to convince you to make the drive!
I like to configure a good hefty pc. of hardwood to to get it under the balancer.
like commando1 I always use the balancer to place the jack under. when the engine is up I put either some wood spacers or sockets between the mounts and frame just in case the jack lets the engine down
