Light package wiring.
Paul Stubbs
I know if I just started to tear into my dash, I would probably get my answer but.....
67 Fury II, is it likely the existing wire harness is pre wired for a map light and ignition switch light (pigtails)?
Doubt if the fender signals would be but that's a lot more wiring.
It's not. For the map and ignition switch light, there might be the plug, usually a multiple female with 3 connectors, that the wiring for those lights will plug into.
Some time with the FSM is in order. Hint: If you have a digital edition, print out the pages. Paper edition, make copies of the wiring pages. Then get out the highlighters and start tracing the circuits.
Stay away from the generic wiring diagrams.
Thanks! I suppose having the plug would be sufficient. I would hate to start splicing things in.
