Location of power window relay70 Polara
JPMODL
WI
Anyone know where I should look to locate the power window relay for my 70 Polara? Neither power window switch works at this time, friend told me to find and check relay.
John
John
Check behind the kick plate on the driver side, might want to check fuses or circuit breaker first. Mopar feeds the rest of the power windows off the master switch on the driver's door, so if there is not power to that switch, none of the windows will work. The cable feeding the switch sometimes breaks off wires from the door opening and closing, so your problem could also be there.
The relay itself is located on the fuse block next to the horn relay. Take a look at the wiring diagrams in your FSM and you'll see it.
The way it works is to supply power to the entire system when the key is on. I kinda doubt that's the issue, but it's worth a check.
The other three windows work fine.
John
To clarify, neither switch for the passenger side rear window works.
Thank you for your help.
John
John
IIRC, a bad switch on either position can cause that... or bad motor etc.
