Longer wheel studs
Kingsport tn
I have a 68 fury iii with stock lugs I need longer stud than stock I have drums allway around I need some suggestions or direction on where to go any help would be great
Longer studs? To use wheel spacers for some non-OEM backspacing wheels or such?
In many dirt track racing classes, they used to require long studs such that with the lug nuts fully installed, there were a few inches of stud exposed past the lug nut.
Longer studs might compromise the installation of any factory hub cap/wheel cover, fwiw.
I have jeep Cherokee wheels on it now no factory wheel I had to use a 1/4 spacer I just need longer stud maybe I’m not sure I’ll take a picture of the wheels on it tomorrow and post it
Here's what you need for the rear.
Do your research on the fronts. Changing front drum studs is a chore.
I know right on the rubber it has 20in wheels I didn’t like them so I found these with rotten tires just to roll on in yard till done so longer studs
Definitely not enough thread engagement.
Are those wheels supposed to use a through style lug nut or conventional conical seat?
