Master Cylinder Mystery
300cruiser
Ontario, Canada
Pulled the car from storage today and the rear reservoir was empty again...same thing last year. It doesn't lose a drop all summer, just when in storage. Front res is fine. The front wheel cylinders were replaced 2 years ago so I don't think they are leaking. Any idea where the fluid is going or why it only leaks while stored?
unbolt and pull the master cylinder away from the booster. If there is fluid behind it, you need to change the master cylinder.
