WANTED Need a 489 center section
MEV
WA
I need a 489 centersection for an 8 3/4. Preferably in washington, oregon, or idaho so i can pick it up. Gear ratio does not matter.
I have a whole rear end in beach north dakota for 200
Does it have a 489 marked center section?
Still looking for a 489 center section a little closer to home. captin71newport went out of his way to help me out, but the distance was a factor.
Any particular reason it has to be a 489? 741, 742 and 489 all interchange as far as fitting the axle housing is concerned. The only thing dedicated to the 489 is the crown and pinion gears. SG units swap across all 3.
Kevin
running a detroit locker and I have several sets of 489 ring and pinion gears already and a crush washer eliminator.
