Hey guys new to the form and are stumped . my late brother had the 318 rebuilt bottom up. and have no oil pressure. crank is good and the bearings are the correct size. any other suggestions.
Could be an oil pressure switch or bad sending unit. I have went through about 3 of them on my 89 dodge ram . It is a very common problem. Do you have gauges or a dummy light? How do you know you are getting no oil pressure?
I would pull the distributor and oil pump drive and spin the oil pump with a pump drive and electric drill. See if there is resistance and if you build pressure.
