Also, I shoot pics or scan negatives and old slides at highest resolution. I can always copy and “save down” on my pc. Have found that around 800 mg horizontally works for emails etc.
They say the 50mm is very good for portraits as is has bigger glass for a low f-stop to help blur the background. It can also be tightened up to get the depth needed to keep the length of our big cars in focus.Exact same camera and lens I have. The first extra lens I bought is the 50mm 1:1.8 lens.
I like the zoom but for up close detail shots I go with the 50mm. I’ve used the manual setting maybe 20% of the time for more artsy shots. Playing with depth of field etc.
At car shows, like today, the zoom is great to frame a car without having to step back 20 ft to get the whole subject. With the 50mm I had to by back at least 20 ft to get a quarter view shot of the cars below.
View attachment 333517 View attachment 333518
This wagon gets around! A handicap tag from Pa. and an EZ Pass transmitter.
I’m happy with the camera after a few years use.
I posted the last on my phone, now that I see it on my computer, it is not very crisp. It could be at 1/60th shutter speed I had a little hand shaking (no tripod or delay timer)On these shots I did a couple of different things. I have a wide angle / macro lens adapter for my old camera. It screws on to the end of my lens. For light conditions it may work ok, but I probably want to get a real wide angle one someday. It requires some cropping as the corners are rounded, but does widen the view. Here are some unedited shots with it. That I downloaded wirelessly to my phone. There is an option to reduce the size.
Car in garage at night so not a bright shooting space. I had to drop the shutter speed way down to 1/50th as I limited the ISO to 2000. Lens aperture at F4.0. Just experimenting.
View attachment 333539 View attachment 333540
This one was at 1/60 f4.0 and 1600. So is a little dark.
View attachment 333541 View attachment 333542
Believe me, 2 mb is plenty big to print an 8x10 professionally. And it transmits easily via the net. Even cropping the image and printing an 8x10 is quite good.
Been doing this photography gig designing, building and repairing cameras now for 36 years.
I sure miss film. Back then you could be a great photographer but the real art was in the lab.
Digital has done away with the chemicals and the errors of photography.
Anyone can be a great photographer today...even me!
The first one was a little hot as I was up to 2500 ISO, I could have also upped my shutter speed a step. What I did was drop it to 2000 ISO for the second one above. A little better, but bright lights in front and less at the rear of the garage don't help.
The second one was the best of the 3 for lighting, but too shaky. I have learned ( if I always remember to shoot with a delayed timers when I am at a low shutter speed.
That is only a small part of the Minoltas as those are most of the rangefinders and only the SRT SLRs leaving out the SR models, XE models, XD models, and all the Maxxums. You haven't seen the Nikon, Pentax, Ricoh, Yashica, Miranda, Topcon, Agfa, Voigtlander, Mamiya, Konica, and Kodak cameras and other miscellaneous brands. View attachment 333299 The TLR is called the Autocord.
