Dsertdog
Old man with an old guitar, and a blue note.
So today I changed the oil in the Polara.
I must have done this a lot of times on big blocks back in the day.
But this time was different.
I drained the oil and removed the Wix filter
I filled the crankcase with Lucas 10-40 and primed the filter with about a half quart of oil, then screwed it on. I've used 10/40 before in big blocks.
The ONLY difference was the filter. I used a 61515, which is the "cheaper" version of a 1515 Wix. It was made by Mann/Hummel, who just bought Wix. Mann is pretty good stuff, so I thought it wouldn't matter. Was I wrong?
Started the engine and no oil pressure. Shut off and restarted several times and still no oil pressure. I panic, things are getting noisy under the hood!
Out of desperation, I put the old Wix filter back on. It's nearly empty. But I start the engine and after a couple of seconds, the light goes out. The engine is quiet. It's awesome!
So...was the filer drain back/pressure relief valve stuck closed? Or too strong to open?
Was the oil too thick to prime? Probably not because it built pressure with the old filter reinstalled.
I'm nervous, but think I should get a Wix filter and change it after priming it so I have a fresh filter.
Any thoughts? I've read a number of posts regarding oil filter/pump failure, oil weight, and filter choices. Some say 10/40 is too heavy.
One thing's for sure, I'm returning the cheapy filters and buying a Wix from now on.
