OK, mechanics
tbm3fan
Pleasant Hill, CA
I am about to go out and do battle with an engine one more time. The car has been sitting for 8 months since the last time I did battle with it and that was the second time since it got laid up December 2015.
To set the picture my wife said there was a tick back then and I heard it faintly myself. A lot like a lifter that might be a little clogged and since the engine had 208,000 miles it could be possible. So I changed out the oil for some Platinum Plus which worked incredibly well with the Mazda's ticking HLAs. The ticking didn't go away this time and decided to look further.
So I took the upper intake off so I could removed the valve cover over the back cylinder for 1-3. Checked rockers, turned engine, checked pushrod clearance and all looked fine. Put all back together except when putting on the upper intake I heard a tink. I didn't see anything but it sounded like something small fell into the lower intake ports. However, nothing was missing, all nuts accounted for, and an optical probe showed nothing.
All together and start the engine only to hear this grinding as though someone was crushing rocks in a pestle. Yikes! Then that sound went away and was left with a loud steady tap. Take a pushrod tip and hit a valve cover with it and you can imitate the sound. So I tear down the engine top to bottom. Everything in the bottom half is fine and the bottom of the oil pan has nothing in it. Heads off and pistons are fine. Pushrods are straight. Rockers normal. Timing chain and gears are fine. Nothing amiss.
Back together and the tap is still there. Since I should have done it the first time I remove the intake to get to the lifters and pull them all to soak and clean. Back together and the sound is still there. So today back to it one more time to fix or get rid of.
The car has been started numerous times and you can hear the tap from 15 feet away easily. When started you hear a rapid ratatatatatat--ratatatat--ratatat-----tap----tap---tap---tap---tap. The first part takes about 2 seconds, small break, another rapid bunch for 1 second before eventually settling down for a stead tap at 900 rpm. Clearly the steady tap is pointing to one piece of the 12 section valve train. With stethoscope the sound is strongest over the back valve cover, not the front, not the center of the engine, nor the timing cover area.
The engine runs fine. Normal rpm, no misses, no codes thrown, live data is normal other than the damn loud tap. Ok, the engine is a 3.0 Vulcan V6 which tends to be a long lasting Ford engine as it is not so powerful as the kill itself. My intention, after taking off the intake assemble is to remove the back cylinder head for another look. Since I have another known good one then maybe place it on the car exchanging out all the valves and springs. So thoughts on what could cause that loud tap that I haven't looked at?
have had flex plate crank , sounds like a tick tick . broken valve spring same type noise . and your engine has roller lifters , have you changed holes with them ?
Lifters are new after the second attempt. Cleaned after first attempt. That was over a year ago from memory.
Today, after taking the back valve cover off I saw four pieces of grit till I removed them and saw they were metal. Ranged in size from 2-4mm square and magnet confirmed metal. They were sitting down at the lower edge of the cylinder head. However, the only way oil gets up there is through the lifters and pushrod where the hole is just under 2mm round. Wondered how they got there? Dark in color and seemed more like head metal than rocker or valve. Anyway the lower intake is ready to be pulled along with that head in this next week.
Just made a recording of that engine noise after going through the top half of the engine. Everything in the block from the top half up is in perfect order from pistons up to rockers and then back down to lifters. All of those moving parts are perfect.
View My Video
The 3.0 OHV is usually really reliable, can't say I have heard one make a noise like that. Did you check to see if when each valve is closed and the lifter is on the base circle that the lifter is preloaded? Did you take the rod's out? Wrist pin? In the video it sure sounds high like valve train though.
capn obvious here,with an old fart trick.
grab a short piece of wood = a plunger handle from the dollar store /any dowel will do.
stick one end on the engine and the other in your ear and move it around the engine till you find the tap is loudest.
as far as the video goes,im hearing 2 diff taps/2 problems.
Is there a chirping noise that seems to move around but seems to be on the drivers side? If so this is the cam synchroniser. DO NOT DRIVE THE CAR. This is the "distributor eliminator" and drives the oil pump. If it fails the oil pump stops.
Common repairs on these engines. I have one and yes, I replaced mine.
