I have always had a parts washing solvent tank. To be fair it is only used in spurts and then sits for a few years.
I have typically used petroleum based solvents. I did try the water based concentrate type part way through my car restoration but didn’t like it as it would flash rust. On the plus side (maybe) if I soaked a part in it a few days it would remove the paint.
I switched back to petroleum based.
Now that I am rebuilding my motorcycle I am putting it back in use. I found that my tank has evaporated down and was filthy. I drained and cleaned and separated the dregs from the better and have about 4 gallons of moderately clean solvent.
Now to replace , I went to my typical sources. Wow in many cases price was 3 times what I expected. $119 for 5 gallons. If I drive 45 miles to a smaller town I can get the same stuff for $74 (5 gallons). By the way NAPA sells it for $33 a gallon. I did find Tractor Supply has it at some stores for under $60 for 5 gallons. But they don’t have it in their local stores so I would also have to drive 35 miles.
I am about ready to go back to the farm mix of diesel and gasoline, but the smell in my garage would drive me nuts, not to mention the flammability may be a little higher than solvent.
I am reluctant to use water based on engine parts and motorcycle roller bearings.
