Please help!! no oil pressure after oil change!!
I can't see what an oil change could do to broke something.
That's exactly the point I'm trying to make also.
Defective filter. Bad inlet check valve.
Also, make sure the seal didn't remain behind when the original filter was taken off. You may have doubled up on the seal.
It's the filter.. :poke:
Wait! :mad:
He changes the oil and filter.
Stop.
He starts the engine.
Stop.
There is no oil pressure.
Stop.
The oil filter is dry.
Stop.
Why is everyone got him doing 1,000,000 things including checking the air pressure in the spare tire?
:drama:
Cantflip, back me up on this. :p
Sold... sorry I'm late to the party.... again. I have doubts about the filter being the problem, cheap to try if you like, but I don't doubt a clogged screen. Distributor is easier than the pan to pop off... but you should pull the pan regardless... at that point, how bad is the pump to do? You didn't really need me for this... everyone was right... it could be all of that stuff or even a cracked pick up tube.
Pull the oil pump off and pack it with wheel bearing grease and put it back on and fire it up. If all is well the pump is worn out.
i agree, sounds like a cavitated oil pump. the oil drained out of the pump and air locked it so it can't pick up oil.
He has already removed the filter and it still won't pump.
Ergo not likely the filter.
Not likely the shaft because he squirted oil in the pump and it shot back out when he turned it over but just friction could turn the pump at that speed so...
The pressure relief valve could be hung open but seems unlikely as once you remove the filter you remove the engine as a restriction so at least some oil should come out of the pump. Path of least resistance and all.
It is not unheard of for a BB Mopar oil pump to just lose its prime.
If it was mine I'd pull the pump off and dismantle it. You can then eliminate all the guess work in a few minutes.
If the end of the shaft is in the pump, bingo.
Regardless, pull the pump apart and inspect the relief valve to see it's not stuck in its bore or the spring is broke and if the shaft was broke, what found its way into the pump to lock it up.
Pull the rotors out of the pump and check the body for scoring and wear. There's a rotor clearance spec in the FSM. It's just a few thou so if the body is all scored or the rotors can be made to more than just detect movement, the pump is worn out and that is likely why it lost its prime.
If everything looks marvelous, pack the rotors full of white grease, put it back on and do the prime with a drill drill and see what you get for pressure.
If still no pressure then it's time to drop the pan and see what has plugged the pick up.
Kevin
Thanks all!
I drop the pan and yes, there was some junk.
I didn't manage to pull the shaft out the dist. way so to night I'm pull out the oil pump to see if the shaft is broken and wich shape the pump are.
I've ordered a new pickup, oil pump and prime tool.
I'll be back with results.
Thanks all!
Show us a picture of the junk so we can advise on what we see and let you know if there is anything else you need to do inside the engine, cheers.
Here's the junk but I belive it's old junk as some of it seems to be hardened corc valve cover sealing and I never used corc valve cover.
No metal what so ever, it's far to light...
Wait! :mad:
Stop.
Stop.
Stop.
Stop.
:drama:
Did anyone mention the thermostat ?
Why was oil filter dry, should always be filled before installation. Is the gear turning on the shaft aftermarket ones are pinned to prevent this.
Once we determined it couldn't be the filter, only then could we move on to step two.
It's called TROUBLE SHOOTING... :poke:
:D
Once we determined it had oil in it, no issue with oil filter because oil wasn't making it that far because it was still empty, the next step for the series of events points reported leading to the problem indicated cavitated oil pump (very unlikely for oil pump shaft or other calamity to happen when shutting down the engine for the oil change while it was parked in the garage or immediately upon startup).
I think dropping the pan wasn't in right order or necessary to find the culprit but sure doesn't hurt for longevity of an older engine, just as moving on to change the timing chain if it's not already a steel double roller, and next changing the valve seals, and fuel pump drive, and getting a valve job, and rebuilding the carb, and pulling the heads for a clean up and valve job, replacing the bearings, and going ahead and getting it boiled out and trued up for some new rings etc.
Coulda been
1. Does it have oil? yes
2. Any issue before driving it prior to going to do or get an oil change? no
3. Any immediate issues after the oil change? yes
4. Is there oil in the engine? yes
0. Is there oil in the filter - no (answered in initial post IIR)
5. Is oil pump cavitated - probably so pull it and fill with grease per priming instructions and see if it resolves problem as it's the easiest thing to check, and most likely the problem with symptoms and details put forth initially
Since you got the oil pan off I would replace the timing gears and chain. Get a timing cover seal set.
