Decided to pull the trigger on a Progression Ignition distributor. I really like the idea of being able to "lock" the ignition and also have the RPM, Speedometer and Vacuum readouts right on my phone.
I did have to grind down about a 1/4" off the cylinder head for it to drop in without interference (stock heads). Otherwise the install was straightforward. An aside, I had upgraded the stock electronic dizzy with the GM HEI setup and the wiring was straightforward.
As for the configuration, these are the options that I started with to create a timing curve:
Idle Speed: 670
Idle Timing: 18 degrees
Max RPM-based timing: 34 degrees (mechanical advance)
All-in RPM: 2750
Max Vac Advance: 8 degrees
Rev Limit: 5500
This is what the timing table looks like using these settings:
I am new to tuning and welcome any feedback from those who have experience with setting proper timing curves.
Idle Speed: 670
All-in RPM: 2750
Rev Limit: 5500
