Tooltime76
Hello,
I am wondering about the Coil/wiring in my 68 Fury, when ignition is on (without enginge running), the Coil measure from + to - connector just 3 volt. I guess this is a bit low, right? It also takes quite some time to get the engine running, could this maybe be the issue?
On the + connector of the coil there are 2 wires, one is going to one of the FLD connectors on the alternator and the other on is going to the ballast resistor.
The prev. owner replaced the old alternator with one that has 2 FLD connectors. But the voltage limiter was still a "old" mechanical one, I replaced it with a plug and play solid state one (Regitar C524). So I guess the second FLD connector should be grounded instead?
On the ballast resistor on one side I measure 12 volt and on the other 3.2. Could the ballast resistor be faulty?
When everything is ok I should end up with approx 8 to 9 volt on the coil, or?
I have a point distributor and the coil needs a external resistor.
Best Regards
Stefan
Best Regards
Stefan
