First, I would give the fast idle cam and the choke butterfly a shot of spray lubricant to see if that improves function. The throttle butterfly should move freely, give it a shot of lubricant also. Next check to see if the fast idle cam drops completely when the engine is warmed up. Check the heat riser to be sure it moves freely, the automatic choke will not function properly without a working heat riser. If you are still having problems, try unhooking the linkage from the choke dash pot. Does the choke butterfly move freely? Sometimes the spring inside the choke dash pot in the manifold goes south and binds up. if so, you will need a new unit. If you replaced the base carb gasket recently, it could be the wrong one and be binding on the car butterfly.
