Roof seam.
carguy300
East Texas
I have a question about my 300 top. The vinyl was removed and there is some pieces of the body puddy at the roof lines missing.Can I just sand down and use body filler, bondo, or is there something better to use prior to a new top?
Couple of pics.
The original material was probably lead, but it might be best to clean/sand and rust coat/treat the area as good as possible, even from the interior of the roof. Then use a quality filler to smooth everything out.
3M used to make a product "AlumaLead" for rust repair of GM lower back glass, in the corners where water would accumulate and they did not paint that well on a vinyl roof car. Something like that, designed for a smaller area spot repair, might work well for the roof/quarter panel seams? You might check the 3M online catalog for more information.
Haven't pulled the vinyl top off my Newport yet. But when working on my Galaxie, we pulled a little to much lead out of the roof seam when stripping the paint. We just used bondo to fill it back up
