Scam or opportunity knocking? "Gorgeous" '59 Windsor in OH for $5.5k
Forward Look Forum
  1. drpreposterous
    drpreposterous Well-Known Member
    655
    443
    Jan 23, 2012
    Clawson (Detroit suburb), MI
    OBO
    No pix, though seller says they're coming...
    1959 Chrysler Windsor - 5500. ob
    Have a beauty of a deal! Gorgeous car with low mileage for a '59 Chrysler Windsor. Very well maintained all these years Hardly any wear n tear int. and ext. 77000miles on the dial. motor and trans run very smooth. Many new parts and Title ready - Pics coming soon show contact info
    call for more info. Plze no texts.thanks
  2. Pete Kaczmarski
    Pete Kaczmarski Senior Member
    2,035
    1110
    Oct 11, 2012
    Waupun WI.
    Put the phone number into a google search with the dashes and put the word 'scam' after it. Then look at the results and see if someone already called it as a scam or if it is listed to a person. The other thing to do is send a email if you can and ask him for the vin. Usually a scammer will not provide it.
    • Agree Agree x 3
    • Like Like x 1
  3. 1970FuryConv
    1970FuryConv Senior Member FCBO Gold Member
    1,508
    1135
    Aug 8, 2014
    Richmond, VA
    Pics now. 4 door sedan with rust. Price is about right. Doubt scam, just didn't describe true condition.
  4. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    Would that be a tall deck 383?
  5. drpreposterous
    655
    443
    Jan 23, 2012
    The ONLY cars on the planet to me that still look cool with rust are the finned ForwardLook beauties.
  6. 1970FuryConv
    1,508
    1135
    Aug 8, 2014
    Richmond, VA
    Someone's got a lot of work ahead of them.
  7. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    • Like Like x 1
  8. twostick
    twostick Senior Member
    1,593
    657
    Dec 13, 2012
    Beautiful Downtown Roebuck Ont.
    The engine pic is an RB. You can see the machined pad 00G0G_cJSiUFwqXJk_1200x900.jpg
    Kevin
    • Like Like x 1
    • Agree Agree x 1
  9. saforwardlook
    saforwardlook Old Man with a Hat FCBO Gold Member
    5,128
    4050
    Oct 8, 2011
    California
    Those were the last of the body on frame forward look cars, with the exception of the Imperials.
    When I see those indications of rust, It makes me want to see the floors in the car. Generally when I see that kind of rust, at every one of the body mount points there is substantial rust. The trunk would show some of it and is the easiest to see. With some of those body on frame cars, I often wonder what kept the body from even staying attached it is so bad. The price is too high for a 4 door 59 Windsor in that condition, I believe. But at least it runs nicely. But be prepared for a lot of body off frame rust repair.
  10. 1970FuryConv
    1,508
    1135
    Aug 8, 2014
    Richmond, VA
    Hi Dana. That's really cool about the 3.75 stroke 383. I edited my post to avoid confusing anybody. Thanks, Ben
  11. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    I got to thinking, would that crank slip right into a low deck??
  12. twostick
    1,593
    657
    Dec 13, 2012
    No, it's the same as a 413/440 crank.
    Kevin
  13. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    Well it says it has main journals the same as 383, 361. I guess my question would be the counterweights. Also one would be make a stoker at the cost of a kinda scarce golden loin motor.
    • Agree Agree x 1
  14. twostick
    1,593
    657
    Dec 13, 2012
    Where does it say that?
    The 383RB was built on the same line as the 413 was. Chrysler would not have tooled up 2 different 3.75 stroke cranks and 2 different main bore RB blocks when all they had to do was change the mold size of the 413RB cylinders. That's assuming that the as cast bore of the 413 block wouldn't clean up at the 4.03 383RB size.
    Kevin
  15. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    Post #7. I just report the news, I don't make it.
    • Like Like x 1
  16. sixtyf
    sixtyf Active Member
    457
    208
    Apr 16, 2014
    New Zealand
    '59 and '60 Windsor and Saratoga models received the 383RB, slightly shy of 100,000 units IIRC.
  17. mopar E
    mopar E Member
    103
    188
    Feb 13, 2016
    Ontario Canada
    Up here in the Salt Belt of S-W Ontario Canada that car is considered in very decent driver condition! If only the Canuck buck wasn't in the toilet compared to the USA dollar
  18. Dana
    Dana Active Member
    238
    180
    Sep 17, 2011
    Ohio
    I agree. I would love to be tooling that around on a set of studded tires right now.:thumbsup:
  19. Bill Watson
    Bill Watson Member
    167
    56
    Apr 18, 2016
    Vancouver, BC
    The US built 1959-1960 Windsor and Saratoga used the RB 383. Helped Chrysler cover the cost of the RB block. The Windsor used a 2-bbl carb and the Saratoga was 4-bbl.
    In Canada, the 1959-1964 Windsor used the B block 361 V8, 2-bbl, while the Saratoga used the B block 383 V8, 4-bbl.
    Checked the 1959 and 1960 parts books and the 1959-60 Chrysler C1 (Windsor) and C2 (Saratoga) RB 383 used the same crankshaft and bearings as the RB 413.
    The RB 383 had a different block casting than the RB 413 due to the smaller bore size. For 1959-1960 :
    B 361 casting number - 2120229
    RB 383 casting number - 2120329
    B 383 casting number - 2120429
    RB 413 casting number - 2120529
    • Thanks! Thanks! x 1
