mr. fix it
Hi guys, I'm asking this question about my 66 Polara Slabbie before actually trying this for myself.
I know that in the past for the 73 disc brake conversions to which I have done most of is this other than replacing the booster.
I replaced every nut & bolt otherwise including upgrading to the 72 2 1/2" rear brakes
Currently I have a 67 drum booster single diaphragm setup.
It's worked ok for the past 1 1/2.
I had the M/C give me some trouble so I replaced it under warranty, bled it and then installed and bled again at the M/C then the distribution block.
I now have a good solid pedal again.
Too good though as the pedal is now to hard for my liking.
I did adjust the booster pushrod out since the replacement M/C piston had a deeper pushrod hole than the original Cordone rebuilt unit.
The brakes work but I have to exert some pretty good effort to bring the car to a complete stop.
With the old M/C I had added a 10psi residual valve to the rear brake circuit since I had to pump the pedal to get a decent pedal. I local performance shop suggested this after I found out that the M/C drum circuit should have a residual valve(which it didn't) even adding a 2nd valve wouldn't hurt if one existed already.
So fast forward to yesterday.I got the new M/C and checked right away for a residual valve & again the replacement did not have one so I left the AM one in place.
I checked the pushrod length and it was really short compared to what the hole in the new M/C needed so I adjusted outwards leaving 1/8" difference.
I did take notice when bleeding the brakes that the proportioning valve on the frame now pushes forward slightly(front circuit) when applying the brakes but the safety light doesn't come on.
I don't think this would cause a hard pedal with 1/8" travel but can't tell for sure since there is limited info out on the web.
I've been googling for an hour plus trying to come up with an answer without having to create this thread.
Is it time for me to bite the bullet and get the dual diaphragm booster or will the 73 single booster work even though it will likely come close to interfering with the column shifter.
Previously, the dual drum booster felt decent but a little effort was needed to apply the brakes safely) not too much but not super easy like new car braking...
Will the single booster work for "drive' position or totally interfere?
I did see an E-body booster suggested on another thread but has anyone confirmed it will work?
Suggestions are appreciated.
Thanks, Tom
Thanks, Tom
