Small Block Engine-Transmission strut information needed
MrMoparCHP
Naselle, WA
I'm looking for pictures of the two struts/braces that go from the side of the block to the transmission.
I know where they mount bot am more interested in the hardware used.
I know these are basically not needed but want this restoration to be complete.
Also I have two different styles and I'm trying to figure out which is correct for a '67
The hardware that was with the ones I received doesn't look factory.
Alan
The bolts I would say are just like the transmission bolts, captive washer and recessed center, or outer raised ring. Brackets I'm not sure.
That is what I was guessing, in my mocking it up I noticed one bolt has to use a nut and I didn't recall that.
Alan
I'm going to have to slide under my Barracuda and see if that hole is threaded on the '67, the transmission I had to play with had a clear bore on the driverside and it was out of a '66.
Alan
