EDIT: I had this wrong. Changed to correct.Good Afternoon All
Quick question: To increase the revolutions of the speedo cable, do add or subtract teeth from the pinion gear?
Thanks to all who respond.
Happy New Year
Omni
Good Afternoon All
Happy New Year
Omni
Yes, look in the FSMAre the pinions colour coded for amount of teeth?
Geez... Now you have me questioning my answer.Less teeth spins the cable faster and shows more mph? More teeth slows it down?
OK, that makes sense.Chart says a bigger tire spins the driveshaft slower so fewer teeth are used to speed the cable up.
Then we actually have to crawl under the dash... and we don't want to do that anymore.....But, the real problem is, what do we do when the cable spins, but the needle don't move?
Brewer's Performance - Mopar A833 4-Speed Transmission and Component SpecialistsThank you all for the responses.
Yes, I am referring to the gear at the end of the cable.
All the charts I have found are for '66 on up when the speedo gears were re-engineered. I am working on a '65 with the small speedo gear (16tooth currently). My tire size is 28"diameter (225/75/15), with a rear gear of 2:76. Original tire (8.25-14) is, from what I researched, 26". Haven't found any chart that deal specifically with bias ply, so, using what they offer as metric equivalents is where I got the 26" from.
I went through this with my 65 Mustang. Here’s what I did:Thank you all for the responses.
FWIW, they do make ratio adaptors too. Chrysler used one on cars with steep gears and small tires. It had a .8:1 ratio. You can see this listed in a '65 Plymouth FSM. You can get them in various ratios. I don't think they still make them, but I could be wrong.To the best of my knowledge 16 tooth is the smallest gear available.
Looking at them right now in the '65 FSM, but yes, I would expect the colors would be listed in the parts manual too.No colours in the Service manual, the colours show up in parts manual.
