WANTED TF727 slip yoke
21_forever
France
Hi
I'm seeking for a 727 slip yoke, mine is worn due to a failing U-joint.
29 +1 spline pattern, nearly 10" length, 7260 U-joint.
Thanks
While you're in there, check for wear in the rear bushing in the tailshaft housing, which the slip yoke's ebd slides into. If the bushing is worn, the seal is not far behind, as to leaks and such. If the slip yoke is out, fix these things for a better long-term repair.
If the worn u-joint caused an out-of-balance situation, there could well be some accumulated wear on that bushing.
