69furyIII
- Joined
- Feb 6, 2011
- Messages
- 53
- Reaction score
- 12
Hello, I was wondering how to tell if torsio bars wear out, mine are the originals. Just not sure how long they will last for.
At that point you are in for a full rebuild, ball joints, tie rod ends etc.That sounds good to me, what about the front sway bar, in sure the bushings need replacing , after all there 48 years old,lol
Hi Alan,At that point you are in for a full rebuild, ball joints, tie rod ends etc.
The lower control arm bushings (torsion bar) are first in last out.
As for the sway bar bushing, those can be done independently of the rest.
Alan
Not necessarily, you need to put the control arms in first, then the bars so the bars come out first but it is everything else that needs to come off before the control armsHi Alan,
Aren't the torsion bars first out and last in?
unless they snap in half they are good for life...
Nobody ever told me that. I know mine are not installed as I took them out
Interesting, nothing in my 67 or 69 factory service manuals.In that case, look at the back of the torsion bar, it has a stamping on it. Now go to the FSM, that shows how the factory should have installed them. Most of the time, the factory got it right so if you put them back to the factory specs you should be ok.
Ran across some over the years that were installed to other than factory specs which is why I now always index them.
The bars don't know and don't care what their rotation is, all they do is twist.
Alan
Whereas that may be true, the clocking will not make a difference in the operation, twist is twist the world around.That is true with new ones. Used ones get a memory within the cell structure of the metal. If you change that you are asking for trouble.
Now I would never swap sides of the car with a used bar, that is where that may be an issue.
Alan
Alan
Alan
.... that's interesting
