There are several different coatings on the market so definitely research each before you jump into it. Hard surface versus more of a rubberized type shiny or satin etc. i can get you some industrial supplier names of what our vendors use. If you take a look at a new Ram with the liner from the factory (Installed by Ground Effects BTW) it is a thin coat hard surface version which does OK but ive had some scratches and gouges show up.
As far as truck beds go no - it cuts easy is slippery when wet and is very shiny - I would go with an Armorguard product that is a flat finish and very durable but takes 24 hours to cure. Keep in mind once it goes on it will be near impossible to take off...
I have had it on both of my previous trucks. It held up great if I ever buy another one it would be one of the first things I would add. Mine was Rhino-liner.
The only problem I see with this is future repairs. I had a car come to the shop plus several trucks that I have seen. If there is ever any collision damage that needs to be repaired. good luck getting a body shop to do it. Panel repair or replacement is very hard to do because the coating has to be removed.
