I'm looking for restorable rear door panels for a 67 300 Convertible. Color makes no difference. Solid rebuildable backing. Thank you.
Are these the solid molded panels with the arm rest built in on the 67 300? I have a 68 Newport Vert with those panels. I bought a used pair (blue I think) just to have an extra set, but I have no plans to use them. If those are the same on a 67 I’ll go to my storage unit tomorrow and get some pics for you so you can see if they’ll work for you. Let me know
I have the plastic pieces for sure. Is it the small panel in the back that goes from the door to the plastic panel you also need? I have some rear panels from a 68 New Yorker 2 door (not a convertible) that would be wider but they may be able to be cut down. In fact I have the front door panels from that car also.This is the only pic I could find. I'll need the door panels and the plastic pieces if you have them.
I’ll get you some pics tomorrow of everything and see what you can use.
Mark
Yes the door panels for the back door to the plastic piece also. I have a set for a Ht. I don't know if they will fit and my car isn't here. Thought I would just hunt down a new set from another conv and get them redone. Thanks for the help. I look forward to see the pics.
