jtalberts
When I first got the car, the ignition wire was disconnected from the starting solenoid. Once that went back on the car would start without issues. I changed my speedo cable the other day and the car started after doing so. I went to start the car to let my brother listen to it the other yesterday and I had no power on the inside of the car. Nothing had power. I swapped out my battery with the new one I bought for when the car is done and the same issue. I have no power on the inside of the car. Dome lights don't come on when the door is opened and the accessory items don't come on when the key is turned.
I thought I had it fixed after I got the battery in the car as I was able to start it a few times. I went back out later and the same issue popped up. To me it almost seems like a loose connection if it will work sporadically.
