68 newp 383 2bbl...On what car with what air cleaner housing?
Which is the same filter as the 2bbl 383 takes.Interesting. When we purchased our '68 300 it also had the wrong air filter. There was about a 1/2" gap between the element and the housing. Our car has the 440 TNT filter housing with the twin snorkels.
Thanks....
Also listed for that same application is the bunk filter that I ended up with:
WIX 42044 Info![]()
Fits 2Bbl
or Base Model Engine VIN G; Custom Engine VIN G
Could this be for an LA engine?
If the 2.75" height is too low, perhaps this one is the one you need:
More Information for WIX 42043
Your engine is the same as Medina's, my T-code 1971 Monaco. And yet, interestingly, the WIX 42043 air filter is shown by Summit as fitting your NYer but not my Dodge (I use the WIX 42044 on that car without any issue, which is the same one that RockAuto also recommends -- surprisingly, it seems -- for your car).I should have checked the forum before ordering a NAPA Gold 2044 air filter, but thought I would be safe with such an idiot proof part. Well, this one is also 2.75" tall and too short for the housing (1971 w/ 440).
The only others that NAPA and Rockauto show are FRAM CA127 (out of stock) and Baldwin AF73 / PA693 (call store for availability), 3.5" height.
Edit: K&N website indicates p/n E-1540 - 3.5" high x 12.5" OD x 11" ID filter as the replacement for this vehicle.
Interesting that the Dodge air cleaner would be 3/4" shorter than the NY.... lower hood perhaps?Your engine is the same as Medina's, my T-code 1971 Monaco. And yet, interestingly, the WIX 42043 air filter is shown by Summit as fitting your NYer but not my Dodge (I use the WIX 42044 on that car without any issue, which is the same one that RockAuto also recommends -- surprisingly, it seems -- for your car).
Following this post, I am going with the 42043 for Buttercup, my 1972 NYB (that is the number shown by RA and Summit both for my car, too).
Actually, I checked my orders, and it turns out that I used a WIX 42044 in BOTH Buttercup and Medina. Both have the T-code engine. Both have filters (42044) that fit perfectly as per @71Polara383 and @david hillInteresting that the Dodge air cleaner would be 3/4" shorter than the NY.... lower hood perhaps?
Actually the filter thickness is the same.Interesting that the Dodge air cleaner would be 3/4" shorter than the NY.... lower hood perhaps?
