Ludo
Before I get into all the technical parts involved, let me just say, "Anything can be done with time and money".
For your car being a 1969 some major parts you would need are 1969 only, the dash is the main component as this is a one year only part, (1970 and 71 are different). The best way to go to install the factory system is to get a complete car so you will have all the parts.
Some other things to mention, the firewall carries a different number as when it was stamped ALL the mounting openings were done before being installed in the body. You can make these openings in yours but again having a complete car is the way to go, you will be able to make templates of the openings.
The dashboard on a fusey can be removed without removing the windshield, the upper bolts are a pain to get at, but it can be done.
You will need all the brackets, belts, and pulleys from the donor car, also the water pump housing as an A/C car has a 1/2" heater hose fitting instead of the non A/C 5/8".
You will also have to remove the passenger side fenderwell and possibly the fender to gain access to the firewall to make the modifications.
I would check out Alan's thread on his 1969 Polara C.H.P. restoration as he has some very good pictures on the disassembly and firewall as he was putting the car together, you can get an idea of what you are in for.
is it possible to send a link to the page from Alan? can not find it
