Is there anything I need to do or a trick to removethe drums on 1954 Windsor? They spin but will not pull off or move out at all. I'm thinking it maybe rusted good to the axle. I banged on it with the hammer a bit but to no availability...
Tours conducted Mon-Fri, 10:00 AM - 5:00 PM by appointment only.
For the fronts do I need to remove the center nut or do they just slide off?
If by center nut, you mean the wheel bearing nut, yes. It has to be taken off. The brake drum and hub are one piece.
You may have to screw around with the adjusters too. Do yourself a huge favor and buy the service manual CD.
This one is the factory version: http://www.ebay.com/itm/1953-1954-C...anuals_Literature&hash=item2573a1e79d&vxp=mtr
Oh yeah... front brakes on an early fifties Chrysler is not for the faint of heart. You really have to know what you are doing and have the correct ($$$) tools to set it back up correctly. There are multiple adjustments to get the brake shoes in the correct position.
The rear brakes are easier to work on? Is it possible to remove the whole brake assembly and take it to a brake shop and install it after?
To put the drum back on just tighten the nut? Will aslide hammer work? Do you know of any good vintage car (brake) shops in the Los Angeles area? I called one brake shop but I don't think they know what this actually entails.
