1965 fury manual to power brakes
1965fury4door
Virginia
Looking at swapping to power brakes on my 65 fury 2, I was wondering what all is different. I have another 65 fury 3 parts car with power brakes if the pedal assembly is different, my fury 2 has a new dual pot master cylinder made for a 67 fury. Will I need a new master? I'd have to swap again as this one is probably only 1 year old
1970FuryConv
Richmond, VA
Welcome from a fellow Virginian!
For later c-body cars, the pedal assembly is different. Power brake pedal is taller than manual. Actuator rod uses a different hole in the firewall. I suspect you will have to use the parts car pedal and also have to change your master cylinder.
@Badvert65
