1965 New Yorker......how to change out window motor?
Early C Bodies - The Slab Side Years
  1. emmd61
    emmd61 Member
    179
    102
    Dec 5, 2015
    north carolina
    Hi all. Do you have to pull out the regulator and motor all at once or can just replace the power window motor with regulator not removed? 3 out of four motors presently not working
    • Like Like x 1
  2. mopar440
    mopar440 Well-Known Member
    655
    182
    Oct 17, 2018
    St paul
    Could you post some pics of the regulator when you do this? I have a problem with my non power regulator, and would like to see one on most cars, you remove the regulator and motor together. It's usually bolted to the glass. Then, usually pin it, so the spring doesn't unwind, then remove motor. I'm sure someone will chime in if different
  3. XenonJohn
    XenonJohn New Member
    21
    19
    Dec 26, 2019
    Swansea, United Kingdom
    I did this job very recently and made a video of it.
    • Like Like x 3
    • Thanks! Thanks! x 1
  4. berrries
    berrries New Member
    5
    0
    Aug 25, 2020
    Tempe, Az
    Hi All,
    First off, great video John!
    I recently did the exact conversion to my 66' Fury VIP with the Dorman 742-300, 742-301, and ran into similar issues with the backspacing. But I found that once I spaced the motor not to bind, it was in contact with the window guide so that the window does not have the full range of motion. Does anyone have a solution for this?
