My 1965 Chrysler Newport seems to have some sort of shifter problem. it will shift fine into every gear going down on the column shifter. but if you try to shift back up to neutral or reverse from drive it will not go. wile going back up it will stay in a forward gear while in neutral or reverse until you hit Park. Shift back down it'll go into reverse and neutral just fine until you hit park again then you can't go back through them again unless you shift completely into Park. I have a 1965 factory service manual and have adjusted the cable according to manuals instructions still no change. Any idea why this is?
