Boomer
Need some help from other owners of 300s or models with the same linkage/carb setup for the transmission kickdown. Mine arrived disconnected and when I finally got a chance to look it over this past weekend, I discovered a few things.
First, with the stock crab swapped out for the Edlebrock, instead of one pin for throttle and kickdown (according to the service manual illustration, at lest), this carb has two. Looks like it could easily fit up on the same main pin where the throttle cable is attached, or down below where a large spring now resides.
Second, the original return spring is missing. No idea where to find something like this. The throttle spring looks a bit tired as well so maybe I can track down the pair.
There's a large black spring added to the side and hooked where the return spring would go on the front bracket.
Lastly, no matter where I try to hook the linkage arm, it drags on the vacuum booster hose. The arm actually has a small elbow bend in it so I'm wondering if perhaps someone swapped it around to try to line up with the outisde pin on the Edlebrock crab. Should the elbow face up or down? And which side of the pivot arm should it be clipped to?
I actually placed it on one of the pins just to see if it would fit and left it there. When I started the car later and revved the engine a bit, the car would edge backward a bit, even though it was in Park. Removed the linkage and it stopped. I know the missing return spring is likely the culprit here, but wondering if it might be pointing at other problems too.
Adjusting it properly will be another matter, once it is hooked up properly and operating freely.
Photos attached. Anyone have a shot or two of their linkage for comparison?
