RKC
Does anyone make the rubber engine splash guards for a 1967 Imperial? Thanks!
Yes, I think they are called inner fender "long" rubber sheets. No, the ones you have cited from Detroit Muscle will not work. Imperial is totally different. Thanks!Do you mean the inner fender rubber sheets?
Does the '67 Imperial inner fender opening and upper control arm geometry match the other C-bodies? If so, then is this what you're looking for?
[/URL]
