nornally the fan basically freewheels when cold and shouldn't make any noise... once it gets hot enough air blowing through the radiator onto it, (180 or so depending on the clutches specs) it will then engage and you'll hear the fan...when there is enough air blowing through the radiator due to the speed of the car, the temp of the water in the radiator will be cool enough for the clutch to disengage and the fan will quiet down...if the engine's running really hot for whatever reason the clutch will remain engaged...so to repeat myself, it should be quiet on cold startup and shouldn't make noise till well after the thermostat opens....issues with the one on my camper showed that Hayden, Murray and 4 Seasons were all the exact same clutches (casting numbers,part #'s, engraved numbers) in different boxes and all came out of the same chinese factory....the third one finally worked
Mine is noisy right from when it's first started. I have no choke so I have to Rev it up a bit when cold, the fan is roaring away right from the start. I did take it for a 20 minute ride and it seemed to go away for a short time, maybe above a certain speed? But then quickly comes back again
