The_Eagles’_Nest
So I’m digging into my Imperial with easy things to do. I have replaced a few light bulbs and it has made wonders.
The original headlamps still work but are stuck behind the doors. I suspect the relay or the motor to be bad.
The right turn signal works, front and rear, but not the left. The parking lamps, cornering lamps, side markers and panel lights do not work. I suspect the headlamp and turn signal switches.
The courtesy lamps work but only with the rear doors open, I suspect both front door switches.
That’s a start, but I’m sure I will find more.
