Mine won't adjust correctly since I changed the o-rings...it was really bad when I tried the wrong parts and it is driveable now but when I try to tap it (even slightly) it seems to be "overpowering" to both sides... Hmmm...anyhow, I found a used one on Craigslist and he includes the following numbers
2267282 R11 7131
Is this a good replacement? I just ordered a complete suspension rebuild kit and figure if it's easy enough at that time I will swap out the box.. unless there is something obvious that I am doing wrong... at one point when I first put the valve back on the box, I didnt get the actuator proporly seated and when I tightened the vavle body down, a gap was left (and a terrible mess when I turned the engine on!)...of course, I took it apart and carefully installed it correctly but I am wondering if I damaged the box...I do still have a leak on the box where the steering wheel goes in so that is why I am thinking of just swapping it out... is that an easy seal to change?
All advice and comments appreciated thank you in advance.
#2267282 R11 7131 Mopar Power Steering Gearbox
2267282 R11 7131
