440 engine rebuild
A quick google search on "Atlanta Engine Rebuilders" shows about 15 of them with various reviews from 5 stars to terrible. Here is what I would suggest. Do you know anyone that drag races cars, specifically Mopars? A conversation with people who have raced for many years will assist in getting you to the right builder. Anyone who does lousy work is quickly vilified in the pits at the track.
Also, what do you want to do with the car? Rebuild to close to stock, or performance oriented? What is the budget? I am not sure what "seized" means, sitting outside for 25 years, or thrown a rod at 6000 RPM? The reason that it is "seized" or any damage done, if any, will dictate the complexity, what work needs to be done and ultimately the $$$ that are coming out of your pocket. Be prepared to wait a considerable amount of time as good machine shops are always busy! C Shaft
There must be a car club or better yet a Mopar club in your area with plenty of info and maybe a cheap engine core if needed.
In shopping, look for: recommendations from several racers of Mopar engines, a power hone, deck plates, line hone, and such so that the machine work is great. Which usually means better than OEM production, when it's all said and done. Understand, too, that great machines in an old building, run by somebody who knows what they are doing can be better than a newer building with equivalent machines run by "employees". Talk and watch how they do things, though. Ask questions, too. Ask respectful questions that a newbie might ask, too. How they answer them and in what manner can speak volumes, by observation. Might take a good friend with you in these shopping expeditions, too, for a second opinion/thoughts.
Once the machine work is done, then request parts of at least OEM quality. Do not need "race parts" unless you are going to seriously drag race the motor. Request a Cloyes roller timing chain, too. Ask about the gasket sets (usually Fel-Pro or equivalent), too. Plus type of bearings.
Be careful, too, about the model year of your block if you are going to build another block instead. Verify the date codes and such. In some of the later model blocks, the accessory drives were different with some having bracket mounting holes not where they need to be for the particular model year of brackets and such. Make sure everything matches on both blocks!!!
NW Georgia Mopar club. One of the folks there would be glad to help. It will help you to join. Craig
