69 Chrysler 300, the 440ci is now a 505ci, 727 TF, 4640S Carb (reworked by Woodruff), Edelbrock Performer Manifold, 906 Heads with larger valves, Liberty Crankshaft, Icon Forged Pistons, Lunati Voodoo Cam .494/.513, 9.8 - 10.0 c/r.
I've got the Idle Mixture Screws backed out 2 turns. If I pull the PCV line off of the carb (creating a vacuum leak) engine rpm will drop down to about 500rpm, then quit.
When at normal operating temperature, idle is set at 1000rpm in Neutral. When I put the car into Drive with foot on brake, engine drops to 800rpm. If I then turn on the A/C, engine will drop to about 730-750rpm.
The engine doesn't really like to idle much below that 750rpm mark.
Any others with similar results or can I tweak some more?
Thx
Thx
