67 T&C power front disk
Citrus heights CA
My car came with factory power front disk brakes. I need new rotors, calipers and pads. Im told no one makes rotors to fit my car anymore. Are there any other mopar models that did use that design and will work on my car?
Be better off getting spindles, ball joints and brake hardware from a 70-73 factory disc brake car. That stuffs easier and cheaper to find than your Budd disc brake parts.
Numerous solutions here, but if you choose to stay with the original Budd set up, Dura Brake makes the rotors still, I believe. They DO still turn upon eBay from time to time, but investigate first. For the pads, make sure you find D-10, not widely available, but they ARE still out there. Calipersonline probably still has the calipers, but read up on the reviews, as they seem to be mixed.
If you go with something from a later C-body, Murray Park probably has EVERYTHING you need, and knows which items you do and don't need........
