70 Fury Vert door glass, vent window? need help
moparblood
my drivers window is flapping around, is there a guide plate missing? if so would non vert work?
my vent window stopped working. you can push and pull it closed but something inside isn't working.
hoping to get a heads up before pulling door panels off
1970 Convertible door glass is shorter, top to bottom, than 23 or 29 body. Non-convertible will not work. 27 body only.
You are going to have to remove the pass side door panel and compare, to find out where the door window looseness is.
Sometimes the vent window/door window cranks have broken internal parts. Hope it's external and easy to fix. When I did door window cranks, internals were broken. I had to use the crank assembly from a parts car and then rivet on the window lift arms. Ben
