Golden Banana
Hi folks, I'm trying to get my door glass out of my 70, its 2dr electric windows, as I'm painting the car i need to get the door handle, lock and mirror out, but getting the glass out??? What's the deal?
Its definitely coming out the top!I'm pretty sure it has to go out the bottom of the vent window track, gut the door and unbolt everything, a little trial and error you'll get it.
Alan
Ive tried downloading these files but I cant seem to open them!! arggghhhh!!Page 23-28 in your FSM has procedure and pic.
No FSM? Download it here: MyMopar - Mopar Forums & Information - Service Manuals
Ok, both my 67 Barracuda and my 69 Polara (4-door sedan) came out the bottom.Its definitely coming out the top!
No vent windows or frames on the fusey 2 doors!!Ok, both my 67 Barracuda and my 69 Polara (4-door sedan) came out the bottom.
On those cars the glass and vent frame go in as an assembly from the top once you put the glass in from the bottom of the vent frame.
Alan
Then it should be easy, roll window down till you can see the screws and unscrew.No vent windows or frames on the fusey 2 doors!!
will do slantsix, probably be Sunday at the earliest but i shall anotate all the bolts that needed to come out plus the weather strip and yep it will easily come out!Pictures pls. I have to do same job.
They are big files. I suggest you try it again.Ive tried downloading these files but I cant seem to open them!! arggghhhh!!
were the windows in the up position? I used the access holes in the inner door frame once the glass was out to access the mirror bolts, i needed to get the door handle and the lock barrel out so it was glass out for me, I'm curious now as i move onto the right side!I've taken both mirrors off and put them back on with the windows in place on my 70 300.
I don't remember exactly how, but it wasn't a big deal or I would remember it.were the windows in the up position? I used the access holes in the inner door frame once the glass was out to access the mirror bolts, i needed to get the door handle and the lock barrel out so it was glass out for me, I'm curious now as i move onto the right side!
my brother has a 63 Cadillac and we discovered holes in the chassis rail lined up so you can tap in the freeze plugs!!
.....tell me more! .....either i need 4ft arms or a new,set of tools!I don't remember exactly how, but it wasn't a big deal or I would remember it.
But you are taking the window out to get at the door handle and lock??? You don't have to do that.
