Pete Kaczmarski
1979 Dodge W150 Powerwagon - $1700 (Edgewood)<>
Hey all,
So up for sale I have my 1979 Dodge W150 Powerwagon with the LA318 V8. NP3500 4 speed manual trans W/granny gear and NP203 fulltime 4x4 transfer case. I have put quite a bit of work into her already and now she needs a new owner that can finish some details and give her a good home.
The reason I'm selling is because I recently picked up a newer Dodge ram 1500 so now I have no use for this old girl.
The good:
New spark plugs
plug wires
Battery
distributor cap
distributor rotor
spark control module
spare cap and rotor
fresh rebuilt carb w/ new cold idle diaphragm
new air filter
fresh oil change
new coolant
thermostat
radiator hoses
fuel pump
fuel filter
fuel hose
Tuff Stuff 100amp alternator
aftermarket conversion headlights to 9003 bulbs
new headlight bulbs
new taillight lenses
new taillight bulbs
KC daylighter 130 watt lamps
extra set of heads from junkyard newer dodge 318LA, may flow better after cleaned
Firestone Destination A/T tires w/ >100 miles....yes that's 100!
4X4 works like a dream. it has fulltime selectable between High, High Lock, Low, Low lock, and Neutral which disengages the entire driveline.
clear title ready for transfer
comes with Hanes Manuel and printed wiring schematic
Fuel tank was dropped and cleaned as well as the fuel vent line replaced.
The bad:
Could use some paint if you want it
interior is multi-color but has much better bench seat than what it had before
gauge cluster does not work, cept the amp meter and fuel gauge
e-brake needs to be adjusted
coolant is new but is also murky due to years of build up
KC's are not wired up but come with all the wiring
reverse lights do not work
no radio
Gauge cluster odometer is of course not working so I don't know mileage.
It does have factory A/C but it needs to be recharged and looked at.
$1700 OBO open to possible trades but no junk.
http://albuquerque.craigslist.org/cto/5093564222.html
Hey all,So up for sale I have my 1979 Dodge W150 Powerwagon with the LA318 V8. NP3500 4 speed manual trans W/granny gear and NP203 fulltime 4x4 transfer case. I have put quite a bit of work into her already and now she needs a new owner that can finish some details and give her a good home.
The good:
New spark plugs
plug wires
Battery
distributor cap
distributor rotor
spare cap and rotor
new air filter
fresh oil change
new coolant
thermostat
radiator hoses
fuel pump
fuel filter
fuel hose
new headlight bulbs
new taillight bulbs
The bad:
no radio
