Castle
hi everyone, I have been working on a 1968 Newport....bought it last July. In adjusting timing and idol, I can’t seem to get the curb idol at the spec from my FSM. It calls for it to be set at 600- 650rpm.... but as soon as I get it below 725, the carb starts to have a high whistle sound. Any ideas as to what causes it to do so?
Next question has to do with the gas tank.... there are two vent tubes that come out of it, do they perform the same function, and what is that? Is it bad for engine performance if one of them is plugged up? Why do they go into the trunk cargo space?
Timing question.... I upgraded to a Pertronix mechanical distributor, it seems as though the base timing is way advanced from the FSM spec, is this normal.... the manual spec says base is At 7.5 and it seems to run pretty well between 24 and 28.
Thanks for your input!
ps.... I have a new timing light, digital, with advance and rpm.... among a coiuple of its options.
