Hey, I just put on a new AVS2 Carburetor #1906 650 CFM With Electric Choke, Satin Finish (Non-EGR) and it’s seems that my car is running on a high idol and does not come back down. Can anyone point me in the right direction on trying fix it.
Did you hook up the electric choke to a switched power source?Hey, I just put on a new AVS2 Carburetor #1906 650 CFM With Electric Choke, Satin Finish (Non-EGR) and it’s seems that my car is running on a high idol and does not come back down. Can anyone point me in the right direction on trying fix it.
I don’t know where to find the idle screw unfortunately unless it’s the two screws on front of the new carb. If it is the two screws then yes I did adjust them.Did you hook up the electric choke to a switched power source?
Did you try backing down the high idle set scew a bit?
All new carbs will need adjustments right out of the box.
Using a vacuum guage you can set the carb up to your engine.
Also check for any vacuum leaks that can cause a high idle condition.
Hope this helps.
