SOLD Again rebuilt distributors
halifaxhops
HALIFAX PA
Feedback: 39 / 0 / 0
Contact Seller
Rebuilt Mopar distributors, all clearances checked, disassembled, cleaned, brought back to factory specifications then re lubed and assembled NOS or NORS points and condensers installed so no premature fails with the junk new components that have a very high fail rate. Then ran on one of my six distributor testers by needed RPM. Can curve also if needed using all oem parts no welding and grinding. Have a few hundred cores to choose from so I only list the completed units don't see what you need just ask. Prices range from $85 t0 1600. Been adding them to the new ones as I go.
Slant
Cast iron Prestolite
225 2642795 31/3 New old stock
IBR 4203A Canadian 1842810 $190.
63
170/225 2098671 17/3
65
225 1v AT 2444648 39/4
66
170 2444255
73
225-1 3755042 51\2
225-1 3755042 at 7/3
75
225 3874082 1BBL MT/AT 21/5 $90
76
225 3874714 1BBL MT 47/5 $130
LA
MP
MP tach drive, small block, elect used like new 4120701 30/7$325
64
273 2444448 13/4 MAN/AUTO A
65
273 2444791 21/5
318 2444291 48/4
273 2444853 IBS 4013 A body only 37/4
318 2444259 29/4 AT B/C
273-4 2444853 IBS 4013 5/14 A only
66
273-2 2642460 replacement for 2642238 AT single point Prestolite 42/2
67
273 w/petronix 2642242 no tag
273 2642242 IBS 4013A 7/7
273 2642238 7/7 A/B
318 2642218 16/7 A/B/C
318 2642718 at 18/7 B/C
273 2642242 IBS 4013A 51/6 A ONLY $355
68
340-4 2875105
IBS4015A AT A ONLY
69
318-2 2875747 29/8 AT B/C
318 2875796 46/8 A/B/C
340-4 3438319 IBS 4015C
70
318-2 3438225 7/9 AT B/C/E
340-4 3438325 42/9 AT A-E ONLY
340-4 3438317 IBS4018 1/0 AT A/E $325
71
318 3438225 42/0
340 348522 IBS 4018C 38/0
318 3438225 49/0
72
318-2 36567275 15/2 MT-AT A/B/E W AIR PUMP
318 3656587 17/2 A/B/C/E
340 3656278 51/1 100 Point clone $425
73
340-4 240 HP 3656771 41/2 MT-AT A/B/E
360 3656780 40/2 EARLY C
360 3755365 18/3 C
74
312-2 3656763 12/4 A/MT $140
75
318 3874090 38/4
80
318-2 4111950 46/4
B
MP
B 3656791 Elect 47/2 $180
B 3690431 Elect 24/4 $180
64
361 2444241 43/3
361 2444261 30/3 $300
65
361/383 (2) 2444676 8/5, 6/5 AT=MT
67
383 2642728 32/7 B/C
68
383 2875354 3/8
383-22642727 38/6 M/AT B/C $175
71
383 3438534 25/0 B/C/E
72
400 3656593 11/2 AT-MT B/C
400-2 365696 15/2 B/C ATMT $165
400 3656593 49/1 B/C
400-4 3656329 22/1 B ONLY
76
400 3755157 47/5
RB
MP 3690432 37/0
MP aluminum case tach drive 4120942 54/5
MP Electronic 36590432 49/5, 24/3
MP ALUM TACH DRIVE 412092 48-4
MP 3690432 1980 $175
62
361/383 2095836 2/2 C
63
413 209834 IBS 4011a tACH DRIVE
64
413 2444263 48/3 C $300
413 2444361 (300) IBS 4011C tach drive C only
413 2444263 48/3 C/D $225
426-4 2444247 IBS 4011E tach drive A/M C only $475
65
413 2444867 48/4 C $300
413 2444869 C
66
440-4 MT/AT 2642252 4/6 C/D
440-4 MT/AT 2642252 35/5, 35/5 C/D
440 MT 2642251 2/6 C body
440-4 MT/AT 2642252 48/5, 28/5 c/d
67
440-4 2642730 52/6 B/C $225
440-4 2642899 47/6 MT B $650
IBS 4006z
68
440 2875362 350HP 46/7, 52/7 C
69
69 440 (350 HP) 2875754 33/8 C body
70
440 3438219 350hp 6/9, 37/9 C
71
72
440 3656341 12/2 B
73
440-4 220HP 3755157 26/3 AT B/C
Early pre 1960 59
IBS 4006C 1842810 8CYL $300
IAT 4101X3 chry 6 $175 EA
IAT 4101B 54 Chry 6
IAZ 4003L 60 8 CYL DUAL POINT. EARLY HEMI? $300
IGS-4108 39-40 Chry
IGS 4201-1 needs a vac advance
IBJ 4302A 56 Desoto
IBS 4006C 1959 8 cylinder $190
Non e advance. I have some if needed need the number of it.
No biggie. For now, this sino-knockoff I'm running performs pretty well. Maybe I'll send you the core for a rebuild at some point. I like how they permit oiling through a little port on the side.....
Looks like most 67 down have that on them. Actually prefer it then depending on the oil to splash up to the shaft, oil ports are almost always clogged, that's why the bearings gets wiped out.
New Slant
63
65
66
170 2444255
73
225-1 3755042 51\2
75
76
LA
MP
64
65
273 2444791 21/5
318 2444291 48/4
66
273-2 2642460 replacement for 2642238 AT single point Prestolite 42/5
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
74
318-2 3656763 12/4 A/MT $140
318-2 3656672 48/3 all $140
75
318 3874090 38/4
80
318-2 4111950 46/4
B
MP
64
361 2444241 43/3
65
67
68
383 2875354 3/8
69
383-2 2875747 2/9 AT B/C $165
71
72
74
400-2 3755150 MT/AT TRUCK $150
76
400 3755157 47/5
RB
MP 3690432 37/0
Mp Mallory style adjustable NOS $175
62
63
64
413 2444869 C
66
67
IBS 4006z
68
69
70
71
72
440 3656341 12/2 B
73
Early pre 1960 59
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
IBP-4003L 1889564 10/P 60 DART $170
413 2444361 (300) IBS 4011C tach drive C only SOLD
Slant
63
65
66
170 2444255
73
225-1 3755042 51\2
75
76
LA
MP
64
65
273 2444791 21/5
318 2444291 48/4
66
318-2 2444259 19/6 AT B/C $135
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
318-2 2875796 31/8 AT/MT A/B/C $160
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
74
75
318 3874090 38/4
80
318-2 4111950 46/4
B
MP
64
361 2444241 43/3
65
67
68
383 2875354 3/8
383-2 2875354 8/8 AT B/C $150
69
71
72
74
76
400 3755157 47/5
RB
MP 3690432 37/0
62
63
64
413 2444869 C
66
67
IBS 4006z
68
69
70
71
72
440 3656341 12/2 B
73
Early pre 1960 59
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
Slant
63
65
66
170 2444255
73
225-1 3755042 51\2
75
76
LA
MP
64
65
273 2444791 21/5
318 2444291 48/4
66
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
70
71
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
74
75
318 3874090 38/4
80
318-2 4111950 46/4
B
MP
64
361 2444241 43/3
65
67
68
383 2875354 3/8
69
71
72
74
76
400 3755157 47/5
81
400? 4091018 37/1 lean burn, nos $175
RB
MP 3690432 37/0
62
63
64
413 2444869 C
66
67
IBS 4006z
68
69
70
71
72
440 3656341 12/2 B
73
Early pre 1960 59
IAT 4101B 54 Chry 6
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
I have been asked if I will be at Carlisle this year I am not but can deliver I am sure.
New Slant
63
65
66
170 2444255
73
225-1 3755042 51\2
75
76
LA
MP
LA 3690430 28/8 $170
64
65
273 2444791 21/5
318 2444291 48/4
66
67
273 2642238 7/7 A/B
68
340-4 2875105
IBS4015A AT A ONLY
69
70
71
360 2V 3438422 A/M C ONLY $125
318 3438225 42/0
318 3438225 49/0
72
73
360 3755365 18/3 C
74
75
318 3874090 38/4
80
318-2 4111950 46/4
B
MP
64
361 2444241 43/3
65
361/383 (2 OR 4V) 2444676 8/5, 6/5 AT/MT
361/318 (4V 0R 2V) 2444676 C ONLY 38/4
67
68
383 2875354 3/8
69
71
72
74
76
400 3755157 47/5
81
RB
MP 3690432 37/0
62
63
64
413 2444869 C
66
67
IBS 4006z
68
RB 2875346 $140
RB 2875346 $150
69
70
71
72
440 3656341 12/2 B
73
Early pre 1960 59
IBS 40067D/1345967 DODGE $180
IAT 4101B 54 Chry 6
IAZ 4001A 1345967 C-52, C-55 $180
IGS-4108 39-40 Chry
IBJ 4302A 56 Desoto
361/383 (2 OR 4V) 2444676 8/5, 6/5 AT/MT pending
