Bias Ply versus Radial Tires: Which Are Best For The (Chrysler) Imperial
The following remarks are from the link I posted:
And from Dick:
There is a lot of misinformation about putting radials on older cars. As a reformed former tire recap plant worker (inspection and preparation machine operator for tread application, in my teens) and the son of a tire designer (B.F.Goodrich), I have always been interested in tires and their design characteristics. While this doesn't make me an expert, I think it may give me more skepticism about some of the strange stories we all hear.
My experience and opinion, for what it is worth, is that radials work just fine on our cars, with the sole proviso that the toe-in be adjusted to zero, rather than the factory spec for the car if it was originally designed for non-radials. Failing to do this will result in the car wandering and a tendency to nibble at the seams in a cement roadway.
There is a different riding characteristic, and a much changed feel at the steering wheel.
First, the cars without power steering will be VERY hard to park with radials, as they grip the pavement with a much larger contact patch and really hold on!
Second, the low speed ride will be harsher, as you will feel every tiny road imperfection you drive over. This is why the manufacturers put different valving in the shocks, to try to filter out some of this road feel. That was the origin of the term "radial tuned shocks".
The high speed ride will be much better, however, as the tires seem to float over rapid disturbances without transmitting these to the unsprung components.
The handling and steering response will be much improved, as will the traction on slippery road surfaces. The tread-wear is much better also, if that is of any interest.
My new 1958 Peugeot came standard with Michelin radials, as did my very un-new 1968 Mark III (to save an argument, yes it is titled as a 69, but it was built in April 1968).
I have used radials on everything from my 1948 Studebaker with it's "planar" suspension (a sideways spring) to my torsion level Packards, and if it weren't for the odd appearance, I'd probably have them on everything I own.
I believe there is only one brand to buy, and that is Michelin. You get what you pay for. I sure wish they made a wide whitewall!
